48 loader on with cab???
John
10-27-2002 16:37:50
I just mounted a JD 48 loader on my 3020 with a year around cab on it I had to cut about 4 in. off the mounting brackets on each side in the back to fit because the cab brackets are there. How many bolts should be in each side bracket I have 7 grade 8 bolts do I drill the rest of the holes in my tractor frame rail for more bolts or is this enough? Are these side rails tough enough to hold up?? All I have left to do is mount the valve bank in the cab, If anyone has a good way or idea to mount it I would like to hear. I am going to try and make a bracket on the right side to hold it just under the window and next to the door. If you have a picture of how yours is mounted I would like to see that.
