John Deere H radiator cap
JRH
10-26-2002 18:58:12
The radiator cap on my '39 H fits loose. The diameter doesnt match the filler neck at all, about 1/4 inch slop or more. I ordered a new cap from Deere thinking the cap that came on the tractor was the wrong one. The new one is exactly like the old one. I checked over the radiator and everything looks to be original there. Any ideas?
Thanks for the help,
John
BMAN
10-27-2002 14:07:15
 Re: John Deere H radiator cap in reply to JRH, 10-26-2002 18:58:12
I have a 1940 H and the radiator cap fits pretty tight.
Rick Hess
10-27-2002 07:11:24
My 1941 H has the original cap and it is loose. I thought it was supposed to be that way. Does being loose cause it to overheat?
JRH
10-27-2002 13:01:49
 Re: Re: John Deere H radiator cap in reply to Rick Hess, 10-27-2002 07:11:24
I don't think it will cause it to over heat since it is not a pressurized system. It can as on mine alow some leaking around the cap when driving over bumps and rough ground.
Thanks to everyone for there input on this.
HMan
10-27-2002 06:19:18
Ditto, I,ve got 2 of them. One has an original and one a repop, both were loose. I changed the seal to a thicker one. They are tight now. About the best you can do with what you have to work with. HMan
Frank M.
10-27-2002 05:41:27
Just want you to know you're not alone. Mine's the same way. Maybe someone on here will have an answer that'll help both of us.
Catch ya' later
Frank M.
Jimbob
10-28-2002 15:13:27
 Re: Re: John Deere H radiator cap in reply to Frank M., 10-27-2002 05:41:27
I put a new seal in the cap also and that fixed it on my '39.
