60 Clutch
Bill
10-26-2002 12:15:51
The clutch on my 60 will not disengage, I have to start it in gear, I am trying to find out weather it is a simple adjustment or do I need to rebuild the clutch. Once I get the tractor running the clutch is fine, but It just wouldn't disengage. How would I go about fixing this. Thanks
Clooney
10-26-2002 12:49:46
 Re: 60 Clutch in reply to Bill, 10-26-2002 12:15:51
Bill, see the link for a recent post on clutch problem areas, the tractor is different but all the clutch parts are about the same. ~I would look closely at the operating sleeve pin & pin hole in the sleeve. That is one thing that will cause the clutch to operate different when running & stopped. You might try backing the adjusting nuts up 1 or 2 notches to see if that helps....
