Aluminum pistons for John deere
Darin Haugen
10-26-2002 00:06:12
Help where do I find aluminum pistons for a JD A or B and what is a power block what is the maximum engine bore on a deere
2 cylinder
10-26-2002 08:44:09
 Re: Aluminum pistons for John deere in reply to Darin Haugen, 10-26-2002 00:06:12
You can usually find used aluminum pistons at most JD salvage yards. I got a new set for my JD-A powerblock (aluminum high compression, .125 over) from Hinrichs Repair at (815) 778-1900. If you get the Green Magazine they have ads listed for both new and used sets. As far as how far you can bore a powerblock, I have been told the furthest you can go is .250 over. But you probably won't be able to do field work with it, just tractorpulling. Hope this helps! Dan
