720 tranny problems HELP!!!
Brad
10-25-2002 20:37:46
I have a 1958 John Deere 720 Diesel, Electric Start, It had alot of noise in the tranny and I started tearing it apart and the sliding gear shaft has a broken bearing on the left side and it has cracked the housing, plus the atleast one of the gears if ruined and the housing also. Should I save money and find a housing and gears or part it out and find another one. It has a factory wide front and 3pt. hitch it runs good and has straight sheet metal and is in other wise good shape. Need advice. Thanks in advance.
Clooney
10-26-2002 03:09:17
 Re: 720 tranny problems HELP!!! in reply to Brad, 10-25-2002 20:37:46
Brad, I can't advise you whether or not to part it out, that is a decision you will have to make. But I can give you some data to help you decide. ~Transmission parts are very expensive for the 720D trans [I just did one about a month ago & had over $500.00 in just bearings, gaskets & misc.]. If you add in gears, shafts & a case you are looking at considerably more. If you sit on it long enough you will probably find a donor tractor to donate a case & most parts but in most cases will still need some new bearings & other parts. There were some running changes to the trans & other parts in the 722XXX range of the 720D so watch the S/N range when shopping for parts, I believe the trans case was the same through the 720's but changed with the 730D....
