4020 leaking fluid
Ron Whitney
10-25-2002 10:17:13
This is a folow up on a previous post and I appreciate the advice everyone gave. I removed the sides from the tractor and although the fluid that appears clear and like an oil (I originally thought it was hydrolyic fluid it seems to be coming from the lower part of the radiator. So now it must be coolant and a busted radiator. Does the 4020's use a different coolant than green antifreeze? and any suggestions on why this could have happened? I was just pulling a harrow leveling ground when it started and we have not had any freezes?
Thanks,
Ron
Mark
10-25-2002 16:48:40
 Re: 4020 leaking fluid in reply to Ron Whitney, 10-25-2002 10:17:13
There is a oil return line to the hydraulic pump located on the right side front area of tractor under the radiator. It is plastic and will break from old age and fatigue. Mark..
G-MAN
10-25-2002 10:29:31
Some of the so-called "environment friendly" antifreezes are clear. Cat even sells antifreeze that is purple. Most are green. It could be that the tractor has no antifreeze in it at all. I would remove the radiator for repair, flush the system and refill with a good 50/50 mix or John Deere Cool-Gard Premix Coolant. I would also recommend replacing the thermostats and any bad hoses at the same time, as well as check the water pump for excessive play. It's also much easier and not a bad idea to replace the fan belt while the radiator is out. This should cover all your bases as far as making sure your cooling system is in good shape.
Ron
10-25-2002 12:20:21
 Re: Re: 4020 leaking fluid in reply to G-MAN, 10-25-2002 10:29:31
thanks for the advice. I will do that. It must have something in it because it is a consistancy of a light oil or something? who knows.
But thanks!
Ron
