Chris, Good thought, but many times old 6VDC vintage generators can handle an increase in field and armature levels for doing 12 volts. Us guys who get a kick of a cheap fix working even like to think we'll find a pulley to turn the gen faster, and make it work that way. When I went thru the pros and cons of converting my red tractor, I figured the least I'd be in for is a new voltage regulator, a dropping or ballast resistor into the coil, and some new light bulbs. Stage two said Murphy's law would have me going to a 12 volt coil and a 12 volt generator, if I could find one, or a rebuilt one as you suggest. After that, I saw stage 3 as going to an alternator, switching from pos to neg ground, a cobbled up alternator mounting bracket and maybe cutting into sheet metal -- might as well throw in an electronic ignition while I was at it. Seemed to me it was just easier to make 6 volts work like it did when new - and the price came in somewhere between stage 1 and 2 of the conversion. Also seemed to me that the reason for the shift to 12 volts originally was because copper prices spiked farther and faster than lead and acid prices -- so it was/is cheaper to use thin 12 volt copper cables and 3 more cells in the battery than it was to use big cables and 3 fewer cells. Granted, this is on a 4 banger that doesn't have 500 some degrees of no spark, and starts quickly anyway. I'm glad my popper is originally 12 volts. If it were a 6, the decision would surely have been closer. What frosted it for me was when I found that when the old generator's brushes acutally pushed down tight, the thing got charged like it should, and was a really happy camper. If I had a similar situation with a B, I think my first step would be to see if I could get two six volt batteries in the box - under the seat type should be no problem. Then if my clean up on the existing system didn't make me happy, the new fat cables surely wouldn't hurt anything and I could stick in a 2nd 6 volter to make 12, change the regulator, add a dropping resistor to the coil and probably blow out all the light bulbs 'cause I'd forgotten about them. Lots of ways to do it; even slow cranking is better than hand cranking -- but even for somebody who's not a stickler for detail, an alternator doesn't look right sitting in an old popper. Steve
