Where do I start with my 3010?
bernie
10-25-2002 07:06:46
I have a 3010 with a syncro-range transmission. I was on level ground running the engine at about 2000 rpm and positioning the tractor next to a building when I decided to quickly jump off and move something on the ground. I thought (I would swear!) I put the transmission in park, but it looks like I must have put it in first, because the tractor lurched forward about 6 inches when I let out the clutch. I put the clutch back in real quick, but then found that the tractor didn't want to move, like it was stuck in park on a hill. I could put the transmission in gear, but when I started to let out the clutch, the wheels would turn maybe one or two degrees and then the engine would lug down like the wheels were locked up. I rocked the tractor back and forth and finally got it to move, drove 100 yards back to the shed, all the while with a low clunking/scraping sound coming from somewhere. Before I shut it off, I noticed that standing still with the transmission in park or neutral and the clutch out, the tractor still made the clunking sound. Where do I start?
dave
10-25-2002 08:16:21
 Re: where do I start with my 3010? in reply to bernie, 10-25-2002 07:06:46
i had the same problem with my 3010. It is caught in two different gears right now. i do believe you may have to split your tractor if you can't get it moving again. when we split the tractor, we found one of the synchro packs. not too hard a job if you have the service manual beside you. good luck.
p.s. rock the tractor and see if you can unlock the gears.
