Michael, the answer, like many we have to post on these boards, "depends". In this case, the answer as to what size ballast you should use depends on the resistance of your coil and assumes youre trying to use a 6 volt coil on a 12 volt system as is common on many older John Deere tractors. What tractor and coil and system are you working with??? Are you sure its a 6 volt coil??? Basically, you want to drop about 6 volts across the ballast which leaves 6 across a 6 volt coil as it was designed for. In order to do that, the resistance of the ballast would be about the same as that of your coil once its up to temperature in its dynamic operating state. You're building a voltage divider with 6 volts across the ballast and 6 remaining across the coil. Many typical 6 volt coils are under 2 ohms, possibly in the 1.5 to 1.85 ohm vicinity. Many 12 volt internally ballasted coils are in the 2.5 to 3 ohm vicinity. Therefore, first check the DC resistance of your coils primary as measured between its lil + and -terminals. Then (assuming its a 6 volt and youre on a 12 volt system) use the resistor or combination of resistors, which is about the same or slightly less than the coil. My guess would be the 2 ohm would be nearest correct. The NAPA sold Echlin ballast is around 1.85 I believe. The 1.2 ohm ballast would provide more spark energy but may cause the coil to run slightly over warm and the points may burn up a little sooner than otherwise, assuming you really have a 6 volt coil and its primary resistance is somewhere between 1.5 but under 2 ohms. If the tractor is equipped with a ballast by pass starting system, when cranking the coil receives unballasted battery voltage. That requires a wire from an extra lil terminal on the push type mechanical start switches or the extra lil terminal on the electric solenoids which feeds the coils high (not to distributor) side and is hot ONLY when cranking. Then once it drops out, the coil receives its voltage from the ignition switch via the in line series ballast leaving 6 or a lil more across the coil so it runs at the proper current and temperature. If you used the 1.2 ohm versus the 2 ohm or if you used a ballast of too little resistance in general, the coil may run too hot. Once warmed up you should be able to lay your hand on the coil and it be naturally warm, but if its so hot you can hardly keep your hand on it, thats too hot and you need more ballast. Short summary answers: Youre tryign to drop around 6 volts across the ballast leaving 6 or slightly more across the coil,,,,, and use the ballast or combination which is approximately the same total ohms as that of your coil once warmed up. Best and safest guess would be to start with the 2 ohm, but if the spark is too weak and the 1.2 works but the coil does NOT overheat using it, it may be better as far as spark energy is concerned (even tho points may burn up slightly quicker if thats too little ballast). ANSWER DEPENDS ON RESISTANCE OF THE COIL REMEMBER. A final but possibly a Rube Goldberg answer would be to make use of all 3 resistors for a combination of 1.55 ohms. The 2 and 1.2 in parallell (.75) in series with the 0.8 = 1.55 total ohms lol. I had an entire article in Greem Magazine a good while back on Ballast Resistor circuits, post back or e mail me at [email protected] with any questions or if you want a copy. Good Luck, let me know John T Nordhoff
