4020 Propane with TWO batteries?
Don Arburn
12-26-2003 11:31:08
Help!
I'm a hobby rancher in South Texas and I've got a mystery in my 4020 Propane. It's got two batteries. The parts guy at the local JD shop AND my Technical Service manual say it shouldn't be that way. Plus there is this little doohickey above the starter on a bracket about 2" wide that says Texas Instruments, it is an electronic something-or-other inline with the wires from the big solinoid post to the key and generator "bat" post. Since the TCM doesn't show but one battery or mention the doohickey, I'm stumped. Is it 24volt ot 12? I'm no electrical whiz, just a tinkerer. Any insight? Thanks!
Don.
Bob
12-26-2003 23:03:08
 Re: 4020 Propane with TWO batteries? in reply to Don Arburn, 12-26-2003 11:31:08
The TI thingy is most likely an automatic cicuit breaker that protects the tractor wiring in case of a short circuit.
DON
12-26-2003 13:01:57
TWO BATTERIES WERE USED FOR COLD WEATHER STARTING. THE HIGHER COMPRESSION NEEDED ALL THE HELP IT COULD GET. THE SYSTEM REMAINED 12 VOLT.
THE OTHER THING YOU MENTIONED COULD BE EMERGENCY SHUT OFF SYSTEM HOOKED TO OIL PRESSURE AND OR WATER TEMP. BUT HARD TO TELL WITH OUT SEEING IT.
