Does this look like a JD piston??
CASEPOWER
10-23-2002 19:31:05
third party image
I don't have the measurments yet, but I was just wondering if it looked like one.. Weight is over 20 pounds.
CASEPOWER
10-24-2002 07:28:28
 Re: Does this look like a JD piston?? in reply to CASEPOWER, 10-23-2002 19:31:05
Well, this is what I found out. It is a 6 inch bore, has a 2 inch pin, and the compression height is 4-1/2. They are from National Transit Engines. And here comes the big kicker!!! The man has over 500 of them yes 500 new in wax paper. Now if only we had something to do with them..
G-MAN
10-24-2002 07:41:26
 Re: Re: Does this look like a JD piston?? in reply to CASEPOWER, 10-24-2002 07:28:28
That's a shame, they would probably work for something like a bored out "A", if it wasn't for that huge wrist pin diameter. I don't believe Deere has anything with a pin that big, at least my "G" doesn't. They're also pretty heavy to be used as a replacement piston.
JDGnut
10-24-2002 10:10:21
 Re: Re: Re: Does this look like a JD piston?? in reply to G-MAN, 10-24-2002 07:41:26
An A?? maybe an A powerblock with some machining on the top.. it would fit in a 70G (but might has well go a little bigger with the correct pin size.) The pin can be adapted.. but with a piston that is that heavy.. The 2 cylinder diesels have piston pin that is bigger than the 2".. but a bigger bore.. (except the stock R's.) JDGnut
G-MAN
10-24-2002 10:43:58
 Re: Re: Re: Re: Does this look like a JD piston?? in reply to JDGnut, 10-24-2002 10:10:21
Yes, I was thinking of it as a piston for a powerblock. Is it possible to bore and sleeve a standard "A" block that big? I think the weight of the thing and trouble of adapting the wrist pin would probably be more trouble than it is worth.
JDGnut
10-25-2002 06:36:57
 Re: Re: Re: Re: Re: Does this look like a JD piston?? in reply to G-MAN, 10-24-2002 10:43:58
Yes the A block could be sleeved to 6in.. its a little different than just boring a block and installing a sleeve.. Actually the pistons pin is not much of a problem.. this is done all the time.. Make a bushing for the piston to fit stock pin.. You can even offset the hole in the bushing to change compression, rod length or whatever.. Sometimes the bushings are welded to the piston to keep them from working out.. JDGnut
Ty
10-24-2002 06:01:48
Kinda looks like one. There would be numbers on it. If I remember correctly my 70D had 6 rings but the top one is reinforced. And also those big old oil pulls and other monsters that had 2,000 CI motors had giant pistons too!
twopop
10-24-2002 05:14:48
i am not and expert by any means ,but i dont think it is a deere piston.i dont think deere used 6 ring pistons.
Frank M.
10-24-2002 05:07:16
No that looks like a Diet Pepsi can. Don't know what that thing beside it is. Sorry, sometimes I can't help being a smart a$$.
Wish I could help you though.
RLA
10-24-2002 07:54:26
 Re: Re: Does this look like a JD piston?? in reply to Frank M., 10-24-2002 05:07:16
With 500 of these, one can go into the business making nitelights for sidewalks. Install some kind of a base & 15watt bulb hooked in series. If you hit one with the mower, you'd be first to know!! RLA
