JD 40-S Steering Shaft ?
Ford Man
10-23-2002 17:58:23
I have a 1953 JD 40-S . The steering shaft that goes from the worm gear to the tie rods is an early style and only has one pin that rides on the worm gear . There is a later model shaft with 2 pins on E-bay ( item # 1779476390 ) . The seller describes it as part # TA124989 and that it has 10 splines and fits fits a 40 or 420 . Will this really fit my tractor ? Will it reduce the play and feedback ?
Please let me know .
Thanks !!
Ford Man
Bill
10-24-2002 04:30:15
 Re: JD 40-S Steering Shaft ? in reply to Ford Man, 10-23-2002 17:58:23
No it will not fit. You can't put a 2 pin shaft in a 1 pin box. The early 40 used the same box as the model M.
Ford Man
10-24-2002 04:39:37
 Re: Re: JD 40-S Steering Shaft ? in reply to Bill, 10-24-2002 04:30:15
Bill ,
I was afraid that might be the case .
Thanks for confirming it and saving me some money and grief !
Thanks Again !
Ford Man
Bill
10-24-2002 16:46:46
 Re: Re: Re: JD 40-S Steering Shaft ? in reply to Ford Man , 10-24-2002 04:39:37
BTW, you can buy a new pin for about $20 from JD. Bushings and seals for the shaft you can get at a bearing supply house cheaper than JD. That will take a lot of the slop out.
