Hard to read serial number ??????
Steve
10-23-2002 08:05:42
I have a J D "R" that the serial number numbers are very hard to see, even with a mag glass. IS there some way of bringing out the numbers? I was thinking of purchasing it.What do I do if I can't read it?
KrisA
10-24-2002 09:44:06
 Re: Hard to read serial number ?????? in reply to Steve, 10-23-2002 08:05:42
Try using just a plain sheet of paper and lay it over the plate and color over with a pencil. That might work! Not too sure but seems to work in some instances, depending on the severity of the wear! My 1.5 cents
KrisA
Jerry S
10-24-2002 09:26:45
I heard from the state bueau of investigation guy that they can get serial numbers from a gun that has had the numbers ground off by putting an acid (not sure which one) on the metal and because the metal under the numbers is more compressed, the numbers will reappear somehow. Maybe something like that would work for a serial plate?
CJDave
10-24-2002 06:18:18
Steve, My wife suggested that I soak the number plate on our "A" with coca-cola and let it sit overnight. The next day when the sun was just perfect I could see the number.
