720D COMPRESSION
TRKTRPULR
10-23-2002 06:50:03
IS IT POSSIBLE TO HAVE TOO MUCH COMPRESSION? WHATDO YOU THINK?
Clooney
10-23-2002 08:49:12
 Re: 720D COMPRESSION in reply to TRKTRPULR, 10-23-2002 06:50:03
TRKTRPULR, define your question a little more. Do you think you have too much compression on your 720? Or do you want to add more compression for pulling or other reasons? The compression isn't easy to change on the 720 as the head is flat so milling it doesn't change anything. ~Long term carbon build up will raise it though.
~As G-MAN said raising the compression also raises the pumping losses & you will have more heat & a higher C-tane fuel requirement. So the basic answer to your question is yes....
G-MAN
10-23-2002 07:35:14
In a diesel tractor, I believe it is possible to have too much compression. In a diesel, you're only compressing air, not a fuel-air mix as in a gas burner. As long as you have enough compression to properly heat the air to provide good ignition upon injection, that is all that is required. Obviously, the more you compress the air, the hotter it will get and you will get a better fuel burn and some more power, but it also takes power to push that piston up on the compression stroke. The more compression you're running, the more power it will take to power the pistons through the compression stroke. I would think that at a certain point, you will get to a situation of minimal returns. As you raise compression, you're also increasing the load on the internal engine parts, as well as increasing the load on the cooling and lubrication systems. If you're dealing with a spark-ignition engine, it is also possible to have too much compression, as you can get into a situation where your fuel has insufficient octane to prevent preignition and detonation, which will destroy an engine faster than about anything.
