Cracks in Round Spoke Wheel Hub
Murph
10-23-2002 06:10:18
I have an Unstyled A with round spoke wheels on the rear. After sandblasting I noticed one of them has cracks on 3 of the 6 lugs holes. I'm not sure what to do about this. I don't plan on farming with the tractor so should I try to have it repaired or not. Any advice is appreciated.
Murph
KEN C.
10-23-2002 17:49:53
 Re: Cracks in Round Spoke Wheel Hub in reply to Murph, 10-23-2002 06:10:18
I have a 36 A with flat spokes, when cleaned had a crack all the way across. We welded a peice of steel pipe inside the hub opposite the mounting bolts, ground it down smooth and can't hardly tell it unless you look close. Have been pulling it at tractor pulls without any problems. But it has to be welded right because of the cast. Maybe this will help, ken.
