4010 J D hydrulics
BUD D.
10-22-2002 08:19:40
was working in field, lost partial of hydraulics to 3 point lift, remote cylender, stearing.
Any suggestions on what problem is?
MG 3010
10-23-2002 08:45:00
 Re: 4010 J D hydrulics in reply to BUD D., 10-22-2002 08:19:40
Bud,
John is right, the main hydraulic pump is likely starving for oil due to a plugged main hydraulic filter or the suction screen in the transmission. You will need to change out the main filter (about $5 from Deere). When you pull the filter out, look to see what plugged it up. If you see black particles and brass wire pieces, the brakes are starting to come apart. They will continue to plug the filter until you fix them. Hope this helps.
John
10-22-2002 08:57:13
I'd start with filter, suction screen. Could be trans pump or main pump also.
