Fixing a leak on my JD R
matthew trefz
10-21-2002 12:45:44
My transmission has been leaking oil recently around the bottom housing. The leak is right where the two halves meet. It's just behind the clutch on the main frame of the tractor. there's supposed to be a gasket in there that runs around the entire circumfrence of the tractor frame. I would like to get the two halves of the tractor split enough to run a bead of gasket maker around the three sides I can get to. I've got the tractor suspended on jacks and have got the two halves to split a little. However, there are two pins (one on top and one on bottom)that are holding it. Is there some way I can break this thing loose far enough to get that gasket maker in there without doing a complete tear down. Thanks.
Harry Dahlin
10-21-2002 16:58:55
 Re: fixing a leak on my JD R in reply to matthew trefz, 10-21-2002 12:45:44
Matthew: I don't know if that is possible but I just had my "R" apart and replaced the gasket and I have an extra gasket if you need one...I had to go thru the entire transmission. Sincerely, Harry Dahlin
