BORING J.D. R
BIG G
10-21-2002 11:58:02
HOW MUCH OF BORE CAN YOU SAFELY DO? IS 820/30 BORE TOO MUCH? OR AM I O.K.?
smoker
10-22-2002 12:34:03
 Re: BORING J.D. R in reply to BIG G, 10-21-2002 11:58:02
Marlins or Rennaissance one make 6-1/4" pistons for the R. Once you bore it that far, it's useless there after unless you can sleeve it. Your best bet is to get a set out of a 730. 830/820 will work but I think you will get a little bit more compression with the 730 pistons. I have heard that the 830 pistons have valve reliefs in them which makes their compression a little lower. If you're going all out, get the 6-1/4" pistons and cam from Marlins @ 2Cyl. Plus. Get 13mm pumps put on your pump bridge, 830 injector lines, and 830 injectors. Finish it off with a good high flowing air filter. I would probably go with Albert at Rennaissance for the pump and injector work. Another member on here didn't have much luck with his R pumps at Marlins.
Tractorboy
10-21-2002 13:55:37
Why would you want to go that much unless you just want to,as the more you bore out the closer to the end of the block life is . Also the heat buildup from a thin wall is something to ? also. My 2 cents worth.
matthew trefz
10-21-2002 12:46:49
yes, you can go that far. I saw an R on ebay that had it done. I don't know if it's still there or not but you could check.
