John Deere B (styled)
Dave Neumann
10-20-2002 15:26:46
The serial # is not readable. Tractor has rollamatic,cast rims. What else can I look at or get a number off to verify the year.
Tractorboy
10-21-2002 14:03:23
 Re: John Deere B (styled) in reply to Dave Neumann, 10-20-2002 15:26:46
47 48 49 looks to have a 1 piece case so 49 50 and 51 had the 2 piece case . Hope this will help
Stan - Florida
10-21-2002 16:11:34
 Re: Re: John Deere B (styled) in reply to Tractorboy, 10-21-2002 14:03:23
You will find in the PC 330 Parts Catalog that the two piece shifter/quadrant started at s/n 260518. That should be in the 1950 model year.
The square axle started at s/n 260984 and the water pumps came into existence at 306600.
Tractorboy
10-21-2002 14:00:04
Look in the parts book PC-330 on page 66 under gear shifter and see the specs .
easydoesit
10-21-2002 12:39:18
If you can never read the number, You can get close by taking a parts catalog and going down thru each part number break and see what yours has. For instance, the axel mentioned started with serial number XXXXX . If after that go down the catalog and find a different part that was used later or newer to further narrow your bracket. Unless someone has switched alot of parts you will get pretty close. Easy
Bob Collins
10-21-2002 10:06:43
Dave, Give the serial number tag one more try to read the number. Get lots of light and lots of magnification then drop on one or two drops of acid ( I dipped a bit out of the battery), with luck the number MAY become readable, quickly write it down then neutralize the acid with water and baking soda. This has worked for me and takes the guess work out of getting the right part later.
RayP(MI)
10-20-2002 18:00:27
Square rear axle housings started with the '50 model year, although a few extremely late '49s got 'em.
tractorboy
10-20-2002 16:53:01
If it is a 6 speed look and see if the case is split or if it is 1 piece . If the case is split it is a 50 or later . You can verify this by the part # in the books .
bobba
10-20-2002 22:10:15
 Re: Re: John Deere B (styled) in reply to tractorboy, 10-20-2002 16:53:01
What exactly do you mean by the case being split?
Please clear this up for me. Thanks!
Stan - Florida
10-21-2002 04:13:03
 Re: Re: Re: John Deere B (styled) in reply to bobba, 10-20-2002 22:10:15
Bobba,
I was curious, too, so I looked it up in Parts Catalog PC 330. At S/N 260518 the gearshift quadrant was changed from one casting to a two-piece item. There was a base piece that bolted on top of the transmission case and the quadrant itself bolted on top of that with cap screws.
Stan
Richard
10-20-2002 16:39:10
Well,,,roll-a-matic became available in 47.
