Computer question.....
Wayne in Tn.
10-20-2002 08:20:37
Due to all the viruses and another problem, I have had to buy a new PC. It's a homegrown, built by a woman who has a PC buisness in my area. It's GREAT, super fast and five times better than my old one. One thing, I hate to mention to her, because she gave me a good deal. The fan is a good bit louder than the old one. The volume of fan noise is somewhat annoying. Is there some way to muffle the sound, without damaging anything??
Easydoesit
10-21-2002 12:43:48
 Re: Computer question..... in reply to Wayne in Tn., 10-20-2002 08:20:37
Wayne, not to start any trouble...But..
Are you sure that this thing doesn't need a muffler?? My G has one ...
Hardcore Hans
10-20-2002 19:36:53
If the fan sounds normal and just sounds like it's pushing a high volume of air, then really, it is a good thing. I do however know what you mean about it being annoying. I build my own systems because I like to know the quality of the parts going into it. I take these systems to gaming tournaments (LAN Parties) to show them off and play games against everyone. One of my computers has seven fans that all run around 7000 rpms - and it is LOUD. When comparing computers to John Deere's, what I like to do is build my computer like I would build a "puller" and make it the biggest and best it can be - I overclock my processors, motherboards, RAM, and graphics processors to get the highest performance as possible to achieve the highest frame rates at these tournaments and it's important to keep my parts cool... so the fans are definately necessary. One of my other systems on the other hand has a complete water cooling system with a pump and radiator that cools my components with minimal noise, but that was quite an investment (time and money!).
But back to your problem... determine which fan is making the noise. As others have pointed out, you'll usually have atleast two fans... one in your power supply and one on your CPU; however, with motherboards supporting such higher front side bus speeds, it is also common to have a fan on your northbridge chipset on the motherboard. After determining which fan is making the majority of your noise, it is usually easy to find quieter replacement fans, or build a rheostat like Clooney did so that you can control the RPMs of the fan.
If you're not comfortable with making the modifications yourself, then contact the woman who built it for you and I'm sure that she'd be able to make it quieter for you.
Lyle Pfeifer
10-20-2002 18:22:42
Try mwave.com, they have several fans if you can't get the lady to do anything.
Lyle
KrisA
10-20-2002 18:18:13
You can got to a local computer store and get a new fan. They are kinda pricy ($20 or so) but you should be able to take care of it! Thats what I would do. They are fairly easy to swap out too!
KrisA
ChuckW
10-20-2002 15:33:55
most of the new computers have a specific fan setup(shrouds and the what nots). I'm a gateway customer have been for many years but a friend of mine bought a dell and you can't hear it running. My gateway is also quiet. For your information there is a company selling new Gateways on ebay at a great price...just bought one from them...
lc
10-20-2002 14:14:55
Wayne, we have one at work same way (pharmacy). We put it under the counter and that cut the noise about half. It is till way to noisy. Its a compaq computer. I think it has two fans in it. Makes more noise than a refrigerator.
C
10-20-2002 11:20:45
Different brand/quality fans are quieter or noisier. No need to put up with a noisy fan these days. There are quiet ones available. I'd mention it to the lady and perhaps she can swap in a quiet one.
Farmer
10-20-2002 09:59:30
Is it the fan on the power supply or is there an auxiliary case fan or fan on the CPU? You will generally have at least the CPU fan mounted on it and the one in the power unit. Sometimes an extra case fan is put on to cool the inside. Usually these don't make that much noise unless they are defective or something is in their way. I would ask the lady about it. I have replaced cpu fans on computers as well as case fans, don't think I ever had one in a power supply go bad. If you aren't afraid of the inside, pull the case and isolate where the fan noise is coming from, maybe a wire is getting clipped by the blades
Wayne in Tn.
10-20-2002 11:49:23
 Re: Re: Computer question..... in reply to Farmer, 10-20-2002 09:59:30
I think it only has one fan, on the inside. It is all new, does not sound like anything hitting it, just noise of the air whooshing.
Clooney
10-20-2002 12:18:30
 Re: Re: Re: Computer question..... in reply to Wayne in Tn., 10-20-2002 11:49:23
Wayne, depending on the processor in your computer & the case real estate layout there are quiet fans available. I have multi computers around the house, shop, barn, basement that all feed into my main house computer that has a powerful processor in it that makes lots of heat [& noise]. The noise was so bad I machined an adapter to mount an 80mm fan & installed a rheostat on the fan power line to allow me to slow the fan down. While it still isn't completely quiet it is much better, & unless the house is completely quiet you can't hear it.
~Ask the lady that built yours if she can obtain & install one of the new quiet fans or an 80mm conversion. I'm sure she will understand as fan noise is a big factor in some of the new computers...
Wayne,,,thanks to all no txt.
10-20-2002 13:47:45
 Re: Re: Re: Re: Computer question..... in reply to Clooney, 10-20-2002 12:18:30
nt
