HMan
10-20-2002 06:10:05
Re: What unique features should a good workshop have? I am going to build one someday. in reply to JohnDeere2Cylinder, 10-19-2002 18:24:59
My $.02. Start with a good compressor. Plumb around around your walls with rigid pipe and lots of quick airline couplings, then you can use short hoses at the work area. Lots of electrical plugs, you don't want to trip over extension cords. You can,t have too much light. White walls, use pegboard if you can get it. Lots of shelving. I'm lucky, I'm a machinist/tool and die maker for a company that makes store fixtures,we punch our own pegboard and make many different styles of shelving. If you have the room, have a different area for welding,grinding, sandblasting cabinet and other dusty jobs. I use one of those double wide roll around tool cabinets,with no top box. With no top box you have a table and toolbox,just roll it where you need it,saves lots of steps. I like the one leg,jib type hoist. If you go with the jib type, you can mount the large pipe in your concrete when you pour. Make sure it's where you want it 'cause that's where it will stay. I live in "The Heart of Dixie" so heat is not a big deal with me. I use one of those kerosene,forced air heaters when I need to "knock the chill off". I have the use of a well equiped machine shop, however I would still like to have my own Bridgeport mill and lathe in my shop. At this stage, the best advise is what you're already doing, plan ahead! Good luck, HMan
