Clooney what Do you think belt driven hydraulic pump on 39 B
Chris
10-19-2002 07:33:08
I have a small belt drive hydraulic pump. Will the fan gears hold up to this. I would like to use it for things like mowing hay or the cylider on my dump wagon. Are they strong enough or is a pto pump better to go with. It is a flat back. I would add a valve and all. Thanks
Clooney
10-19-2002 08:06:47
 Re: Clooney what Do you think belt driven hydraulic pump on 39 B in reply to Chris, 10-19-2002 07:33:08
Chris, that is a hard question to answer. Those gears aren't very big & by now probably have quite a bit of wear on them. So my first opinion would be not to do it. But I have seen alternators installed on those old B's & a fully charging 65 amp alternator will load those gears as much or more than a light use pump.
~A PTO, or even a crankshaft driven pump would be safer approach. ~In past years I have built & run pumps from a dual belt system that drove directly from the clutch pulley [the inside of the V belt rode directly on the clutch pulley] that worked great. The only problem is the pulley must be engaged for the pump to operate. I have also run a pump from a pulley bolted to the flywheel & that gives [live power], the only problem with using a pulley on the flywheel is there is no good way to do that & make it look even close to a production set-up. [it just kind of hangs out there in the wind, but does function good].
