Flywheel for 730 Diesel
Rick Davis
10-19-2002 05:26:42
need a flywheel for 730 Diesel. Anybody happen to have one. Would a 720 diesel flywheel work?
Clooney
10-19-2002 06:15:58
 Re: Flywheel for 730 Diesel in reply to Rick Davis, 10-19-2002 05:26:42
Rick, the late 720 [s/n 7214900] up is the same. But many of the early 720's have been updated using the better L/H crank cover & seal & that required the later F-3570R flywheel. So don't discount the early 720's without looking.
Clooney (follow up)
10-19-2002 06:21:51
 Re: Re: Flywheel for 730 Diesel in reply to Clooney, 10-19-2002 06:15:58
Be very careful when buying a used 2-Cylinder flywheel, the splines in most are junk. You really need to go & look at any 2-cyl diesel flywheel before buying or get a money back guarantee. There are very few good ones left out there without spline damage.
~You might be better off buying a taper-lock flywheel rather than chancing an original...
