JD Model A weight?
CJDave
10-17-2002 16:49:38
Speaking of tractor weight..... the book we have says that the early 1947 Model A JD weighed 3783 lbs and the late '47 and up to 1952 weighed 4909 lbs. Is that a misprint? Could that tractor have gained 1126 lbs? What was changed? This tractor doesn't SEEM that much heavier than the 1941 AW that I used to run.
Dave K
10-21-2002 14:37:23
 Re: JD Model A weight? in reply to CJDave, 10-17-2002 16:49:38
Those cast wheels are what adds a lot of weight. Mine weighs 5500 pounds with cast wheels.
dave
BUDD
10-19-2002 02:35:18
CJDave;
I have a 49 "A". It weighs 5000 lbs to 5100 lbs depending on the scales. This is without me on it. It has cast wheels (no fluid) power Trol, and starter system. BUDD
rollo
10-18-2002 04:35:16
Wasn't it the addition of cast wheels instead of pressed ones primarily? By the way, my JD operators manual that came with my '47A says the tractor weighs 5,500 pounds.
CJDave
10-18-2002 06:10:03
 Re: Re: JD Model A weight? in reply to rollo, 10-18-2002 04:35:16
It's a mystery to me, but then again I'm a little unfamiliar with the "A" model line, since I only have experience with a '41 AW which had round spoke wheels in back and no external weights whatsoever. There is a grain elevator just three and one-half miles away in town. I have plans to take this tractor to town and take a photo of it backed partially up the ramp of the old, abandoned railroad platform where it was unloaded as a new tractor, so when I do that, I'll drive it over the scale at the grain elevator and see what it says. Thanks for your response.....Dave
