'49 A starter removal
Dutch
10-17-2002 15:31:01
I'm having trouble removing the starter from my '49 AW. I've removed the flywheel cover, the 3 starter bolts behind the flywheel, and the cover underneath. That sucker won't budge. Have I missed a fastener or could it be just rusted in?
Chuck W
10-18-2002 11:05:35
 Re: '49 A starter removal in reply to Dutch, 10-17-2002 15:31:01
GWH is right on. Those starter when loose can fall like an anvil. Be sure to get under it and work out the starter. As a matter of fact they are a little dangerous to mess with as most people do not realize the weight factor.
dutch
10-18-2002 17:57:05
 Re: Re: '49 A starter removal in reply to Chuck W, 10-18-2002 11:05:35
It sure was heavy, didn't get me though. I got it out and it was seized up solid. I tapped on it, talked to it, and sprayed it until it came apart.
I cleaned it all up inside and out and replaced the brushes and springs and believe it or not she's whirrin' again!!! What a relief I didn't want to have to spring for another one (the shipping alone would have broke me as it does weigh as much as the engine in many sub-compact. cars)
520-LP
10-17-2002 20:13:10
Remove the battery cable and the rod that goes to the foot pedal
gwh
10-17-2002 19:57:02
Dutch, If you don't understand the word heavy you will when that starter comes out, i would put back in 1 bolt a couple threads leaving it loose before prying or tapping. gwh
Donny-B
10-17-2002 19:30:48
Dutch, Chances are its rusted fast to the casting. I had the same problem on a D. If you soak the area with PB Blaster and tap the rear of the starter left/right it should break free.
Dutch
10-17-2002 22:10:01
 Re: Re: '49 A starter removal in reply to Donny-B, 10-17-2002 19:30:48
I had PB Blasted it before my first post and when I went back to try again I jerked it right out. Thanks for your help.
