How heavy is a B?
Dan Smith
10-17-2002 11:18:17
How heavy is a 1940 JD B styled on rubber? Flywheel start, no wheel weights, no calcium. Needs to come to NJ from Nebraska if anyone is making the trip.
Will P
10-17-2002 18:04:40
 Re: How heavy is a B? in reply to Dan Smith, 10-17-2002 11:18:17
My 43B handstart with cast wheels with no fluid and no wheel weights weights about 3800 lbs. But she is a war tractor with a cast frame. Your angle iron frame 1940 B would weigh less. Hope this helps.
Will P
Stan - Florida
10-17-2002 17:15:32
My Operator's Manual for my 1941 B says 3140 pounds on 10-38 rubber tires with pressed steel rear wheels and rubber front tires on pressed steel rims.
You might look in the Hauling Schedule to see if you can find Skretta Hauling Service out of Omaha. I've known Fabian Skretta for 35 years or so and think he'll do you a good job.
Stan
Green_in_MI
10-17-2002 15:10:35
Intertec guide says the shipping weight of a 1940 B is 4130 lbs.
Jim F
10-17-2002 12:33:07
I would guestamate that at around 3300#.
