Charging problem on a 520
Richard
10-16-2002 16:52:01
I have a new battery in the tractor and it went dead. Tractor has a master switch that disconnects the battery so i know there is not a draw on it.The system is 12 volt neg, ground.Had the generator bench tested guy said it was glazed and clean it quick and said that was my problem.Put it back on tractor and excited the field.(could only get a spark from neg on coil).Put a charging system tester on battery and it says battery is good but no charging.can I test right at generator with digital multimeter? Have all new wireing and double checked routing of all wires.Test light lights at generator and amp meter.Dont know if needle is broken on amp meter but it is hot on both terminals.Charged battery with battery charger but I think its gonna go dead again
Clooney
10-16-2002 17:29:41
 Re: charging problem on a 520 in reply to Richard, 10-16-2002 16:52:01
Richard, first if it's now negative ground [it was built positive ground] is the ammeter wired correctly for negative ground? [if the wires weren't swapped on the ammeter to work at negative ground it will now read backwards]. Turn the headlights on & see if the ammeter reads a discharge, if not it isn't going to read a correct charge.
~If the ammeter is wired correctly the next step is to polarize the generator... Ground the [F] post on the generator [smaller of the two] then momentarily run a jumper wire from the [BAT] to the [GEN] terminals at the regulator, you should see a spark, if so it is polarized, if no spark suspect no power to the regulator [BAT] terminal or open field in the generator.
~If it still doesn't charge run the engine at fast idle then ground the [F] post on the generator, [does it charge now?] if so suspect a faulty regulator, open in the wire from the [F] post to the regulator, or a bad regulator ground...then with the [F] post still grounded connect a jumper wire from the [BAT] terminal at the regulator to the [A] post on the generator [does it charge now?] if so suspect an open in the wire from the generator [A] post to the regulator [GEN] terminal or a defective regulator...If it still doesn't charge suspect a bad generator...To test the generator, disconnect the fan belt & both wires from the generator & run a jumper wire from the[BAT] terminal on the regulator to the [A] post on the generator, it should motor, then ground the [F] post on the generator, it should slow down. If it doesn't motor suspect stuck brushes, an open in the armature, a bad generator ground or other internal generator problem, if it motors but doesn't slow down suspect an open in the field or a brush problem...
~Run some of the above tests & post back with questions....
