What innovative things can I make out of a John Deere?
JohnDeere2Cylinder
10-16-2002 07:47:14
I am parting out a JD A. I am looking for ideas of things to make out of some of the extra parts.
For example: I plan on taking the rear casting with the J O H N D E E R E on the axles and make an overshoot waterwheel. I heat and cool my house with a water-to-air heat pump and whenever it runs I have water running out a pipe to a small duck pond. I want the water to run over the top of a spoked wheel into some homemade cups that when full will turn the wheel in a forward direction. The wheel will be mounted on my J O H N D E E R E axle so the world can see it slowly revolving from the road.
I am also making a pencil holder for my office. I will be using the gear selector metal box (what ever it is called). It is the part with 5-6 and 3-4 and 1-2 and R raised letters on it.
Do you have any other unique ideas for JD parts?
Thanks
Jim F.
10-16-2002 12:21:35
 Re: What innovative things can I make out of a John Deere? in reply to JohnDeere2Cylinder, 10-16-2002 07:47:14
I have made a base for my 6" grinder stand out of a Model B flywheel. Great counter weight and is portable also, just tip it on it's side and roll it to were you need it. Crankshaft would make an interesting mailbox post.
Bob
10-16-2002 10:34:18
How about using the steering shaft for a lightening rod? It'd look real nice on top of your house, especially with the wheel still attached at the top end.
Flywheel'd make a pretty decent boat anchor. Or lid for a cookie jar you don't want to kids raiding all the time.
Finally, with the cylinder block you could make a dandy two-holer out back.
Dwayne
10-16-2002 13:13:21
 Re: Re: What innovative things can I make out of a John Deere? in reply to Bob, 10-16-2002 10:34:18
I've got a great idea for the radiator (if it unstyled. Take out the core and cover the front with a hinged mirror. it would make a dandy medicine cabnet for the two-holer that Bob suggested you build out back.
G-MAN
10-16-2002 13:29:52
 Re: Re: Re: What innovative things can I make out of a John Deere? in reply to Dwayne, 10-16-2002 13:13:21
Maybe a headlight bracket for a super-capacity toilet paper holder?
Dwayne
10-16-2002 16:03:37
 Re: Re: Re: Re: What innovative things can I make out of a John Deere? in reply to G-MAN, 10-16-2002 13:29:52
you could also use the rear axles for hand rails, it would have to be handicap accessable. everyone knows we're just having fun
G-MAN
10-16-2002 08:44:07
A guy north of Beatrice, NE has a complete styled "A" on steel for a mailbox holder.
MNBill
10-16-2002 09:03:53
 Re: Re: What innovative things can I make out of a John Deere? in reply to G-MAN, 10-16-2002 08:44:07
There is a guy ouside of town that has a JD A? on top of his silo and yellow and green checkerboard painted on the top part of the silo. Looks pretty cool....
G-MAN
10-16-2002 09:47:40
 Re: Re: Re: What innovative things can I make out of a John Deere? in reply to MNBill, 10-16-2002 09:03:53
There was a picture in Green Magazine recently of a JD two-cylinder on top of a silo, but I'm 99% sure that one was a "G", as it appeared to be styled and have the side by side stacks.
Plowin
10-16-2002 16:38:18
 Re: Re: Re: Re: What innovative things can I make out of a John Deere? in reply to G-MAN, 10-16-2002 09:47:40
I saw that g on the silo in IN. I think but it was a G.Looked good up there.
ff316
10-16-2002 19:09:28
 Re: Re: Re: Re: Re: What innovative things can I make out of a John Deere? in reply to Plowin, 10-16-2002 16:38:18
I saw the G on silo on RFD-TV one time. Looked like a heck of a conversation piece. I bet you see a bunch of brake lights in front of that place. I know a guy that plans to make a mail box out of a G power block(it's cracked pretty good inside).
Bob
10-16-2002 17:06:49
Do ya s'pose you'd have to fill the tires to get traction going up that steep an angle?
plowin
10-16-2002 20:11:17
 Re: Re: Re: Re: Re: Re: What innovative things can I make out of a John Deere? in reply to Bob, 10-16-2002 17:06:49
Na with a good G put it in road gear she'll make it every time.Had a coupla beers tonight was looking at the silo looked at the G forget it.
Walt in Jaxn, Tn.
10-16-2002 15:53:14
Hey, all joking aside, i made a good boat anchor out of the clutch drive disk. I bolted an 18 in. 5/8 thru bolt (used on power poles) with 2 in. square washers on one end and placed an eye nut on the other end for the anchor rope and used it for years. If you ask nice, a power crew will give you the hardware you need.
