Installing clutch
Larry
10-15-2002 17:20:29
Can someone out there scan a picture of the clutch assembly and directions how to install one in a 730 I got one in a basket and trying to figure it out Thanks
Clooney (slow loading picture)
10-15-2002 17:51:24
 Re: Installing clutch in reply to Larry, 10-15-2002 17:20:29
third party image
Larry, the clutch goes together as the picture shows. Tighten the 3 adjusting nuts to the same torque to start then adjust the same number of turns from there until you get a good solid snap in & out.
~After assembled & adjusted remove the top & bottom little covers on the 1st reduction cover, then release clutch, then use a screwdriver & lightly pry the pulley away from the tractor until tight on the inner plate, then reach in through the top & bottom cover & adjust the fork travel stop bolts until there is .060" clearance between the bolt heads & the R/H main bearing cover.
~Ask all the questions you need to, it's easier to answer questions than type a novel on how to assemble it.
