G-MAN
10-14-2002 15:45:26
Re: JD 4430 Questions in reply to JLC, 10-14-2002 14:22:37
There are no real inherent weaknesses in the 4430, but there are things to look for. First, rated horsepower is 126, although most will probably be a little closer to 140, even at stock fuel settings. Depending on transmission type (quad-range or powershift), you'll want to operate the tractor and listen for unusual noises. If it's a powershift, put the tractor in neutral and rev up the engine. If there is any warpage of the disks and plates in the cluth pack, the tractor will tend to creep forward. If there is severe damage, it may drive away like it's in gear. Drive it and use the brakes to load the transmission to check for slippage. Don't get carried away, but the brakes should be able to kill the engine in any gear at around 1500 rpm. The factory engine in that tractor is the 6404T (404 cubic inches), not the 6466T found in 4440s and later tractors, so it won't have the low-end torque and lugging ability of the newer series. Check the condition of the coolant and lubricants. I would ask what the situation is with the engine being overhauled at 2800 hours, as that is really low for an overhaul. Perhaps maintenance wasn't good on the tractor. A lot of guys will keep the paint and interior looking great, but neglect maintenance of the powertrain. Obviously not a good deal. Check to see how the engine starts when cold. Look for excessive smoke or blowby at the tube at the rear of the RH frame rail. Make sure the hitch operates correctly. Make sure the PTO clutch and brake are operating correctly, also. Make sure that the tie rod ends, steering motor arm, and spindles are tight. If possible, jack up the front end (not under the axle) and look for slop at the axle pivot pins. Look for leaks at the hydraulic pump, SCVs and so on. Basically just look at the same things you would on a used car, and don't be fooled by a new good paint job and nice tires, as those items are relatively cheap compared to major mechanical work. If you don't have much JD experience, I highly recommend taking along someone you know and trust that is familiar with JDs, as they may see things I have missed in this post. It's hard to make a good determination without actually being able to see the tractor. Value could range from around $8,000 or less for one that is really rough with no Sound-Gard, etc to $15,000 or more for one that is in mint condition. Good luck with the 4430.
