HELP-JD 40 SERIAL NUMBER, YEAR OF MANUFACTURE
Steve Hart
10-14-2002 13:07:13
I am new at this as you will tell by my question. I never worked on a farm but I love tractors and I recently purchased a JD model 40. The serial number stamped on the plate is 71664 and the model is a 40. Every book I have bought lists model 40's as 40T,40S,40U etc. mine is a 40. It came with a single front tire which I have read was a option. I am hoping mine was built in 1954. I sent in money to research my number only to be told records on the 40 are not available. I am hoping that the answer is simple like all 40's with a single front wheel are technically 40T's.
Can anyone help me on this. Many Thanks. Steve.
Richard
10-14-2002 15:57:59
 Re: HELP-JD 40 SERIAL NUMBER, YEAR OF MANUFACTURE in reply to Steve Hart, 10-14-2002 13:07:13
My chart only shows a serial range for 40's, 40T's, Hi Crops, 2-row utility, Specials, and the crawlers. All numbers started at 60001. I doubt that enough specials and hi crops were made to bring their numbers up to 70,000. So if a T configuation, the beginning number for 54 would be 69475 and for 55 at 75179.
Wayne in Tn.
10-14-2002 13:58:52
Steve according to my chart, it is a 1954 model. I have seen lots with just 40 and nothing else on the plate. But there were about 5 different front axles available. You could order any configuration you wanted. (heavy duty wide front or regular and different adjustable widths, single front, dual front tricycle) The only 40W was made in 1955. I have seen a wide front 40 with nothing but 40 on the tag, but the final drives were different from a T. So really you can't say all plain 40's are T's
