49G trans question.
Will P
10-13-2002 19:37:34
Just got my 49G running for the first time. Still needs alot of work. But, While running it around. I put it in reverse. The high/low stick was in high. It never kicked it into low. Like my 43A and B do. Is there someting wrong? It moved in reverse high and reverse low. It works. But is it right?
Thanks for your help.
Will P
Will P
10-14-2002 16:40:06
 Re: 49G trans question. in reply to Will P, 10-13-2002 19:37:34
Thanks guys. That is one thing less that I have to fix seeing that it is not broke.
Thanks, Will P
G-MAN
10-14-2002 07:30:44
"G"s do not have the reverse lockout that is found on the two-stick "A". I don't know if the "B"s have it or not.
JohnDeere2Cylinder
10-14-2002 13:55:07
 Re: Re: 49G trans question. in reply to G-MAN, 10-14-2002 07:30:44
I noticed that my 1950 "G" has 2 reverse speeds. I can back up faster to the eliminator than I can go forward when hooked up.
JDG
10-13-2002 21:03:18
I think it must be right mine does the Same thing>
John Brawner
10-13-2002 21:57:03
 Re: Re: 49G trans question. in reply to JDG, 10-13-2002 21:03:18
THIS IS THE WAY ALL OF THEM ARE OR THE ONES I HAVE SEEN ANYWAY!THAT Hi.REVERSE IS FAST TOO !BIG JOHN.
