48 A cam gear question
Jack
10-13-2002 13:06:29
A friend of mine just aquired a good running 48 A and after a little running"bam",a pop and that was it,never ran again.Well I went and took a look and the governor gear busted.He bought another governor and when we went to install it and we could not locate the timing mark on the cam gear.The mark ended up being to the inside of the gear and so was the pn#.I thought the gear mark was supposed to be towards the outside.We marked the outside according to the mark on the inside,and installed the governor.The cam gear seems to be about an 8th inch toward the outside too much but not touching the crankcase housing.Whoever had the cam out the last time put the cam gear on wrong,it looks like.What my question was,(after such a long text)will this hurt anything?Will this affect the distributor timing too?Thankx,Jack(TN).
TedK/MN
10-14-2002 06:57:39
 Re: 48 A cam gear question in reply to Jack, 10-13-2002 13:06:29
Jack-Went through the r/r of the cam gear on my 48 "A" this past winter. Several years ago I installed a "60" governor housing on mine so I could have live oil for my loader and hydrostatic power steering. My cam gear cracked around all the spokes but still turned the cam, ran the hyd. pump, and the tractor ran, but with a strange clatter as the gear wobbled against the main case! But, the marks are on the inside of the gear so as to be lined up with the crankshaft gear mark. The cam gear will only bolt onto the cam in the proper position. Best check the valve timing as instructed in the service manual, then your distributor drive slot will be at the proper position and all will be fine. Good luck, Ted
