720D drawbar
Austin
10-13-2002 12:32:09
I just bought an early 720D with 3pt hitch it came with two drawbars one straight and the other has the drop down end. What one is correct for the 3pt hitch. I want to restore this tractor as close as possible to orignal
Clooney
10-14-2002 09:02:03
 Re: 720D drawbar in reply to Austin, 10-13-2002 12:32:09
Austin, the 720D was offered with a couple of drawbar options including a heavy duty offering. I have owned 720-730's with both drawbar configurations & it seems the bent drawbar was used on the early 720's & the straight one on the later 720's. I usually match the drawbar offset to work out with the tire size on the tractor & to clear the PTO drive shaft of the equiptment used....
Bob K
10-14-2002 07:11:15
I'm thinking the drop-down bar is factory and the straight bar is after-market/home made. Go with the drop-down bar for originality. Good luck on your restoration.
