Wheel won't fit
John
10-13-2002 08:27:47
Located a 49 JD "A" row crop, pretty decrepit, has one rear wheel with cast center, borrowed an all steel wheel to get it loaded. Same number of splines, cleaned the axle splines immacuately, steel wool and sandpaper. The hub slides on two inches and stops, won't slide down the axle any further at all, even after being greased. The tractor serial number says its a 49. The locking wedge is off the wheel, and looking in there, the splines look a perfect fit. Before I go buy a matching cast center wheel, what have I got going here? john
