JD A Rock shaft reassembly advice needed...
jack
10-12-2002 09:14:24
Hi,
My A is serial #654083, believe a 1950 model. I took the power trol unit off to replace cylinder seal and gasket. This removal went great. But the video I have to show R/R of a power trol doesn't address the right hand rockshaft reassembly. When replacing the rockshaft will the rockshaft spring be under tension? Also when installed properly does the crank arm move in towards the cylinder past being vertical with the rockshaft? Also I assume the rockshaft spring's purpose is to return the rockshaft to the lower positions. It appears that I need to reassemble the rockshaft with the spring under tension. Is this correct? Thanks for any help in advance. Jack
jack
10-14-2002 18:20:46
 Re: JD A Rock shaft reassembly advice needed... in reply to jack, 10-12-2002 09:14:24
Morgan,
If saw the arrow on the end of the rockshaft. I love it when it all starts to make sense. Thanks again. Jack
morgan
10-14-2002 08:09:44
To answer part of your question, on your rock shaft, on the right one-there are 3 bolts,you have to take all 3 off and let the end plate swing counter-clock wise, When you put the right rock shaft in the collar be sure the arrow on the end of the shaft is pointing to the word UP on the shaft housing-or if you don't have the word up as on the later A's, point the arrow at a raised projection on the bearing cap.after the rock shaft is in then you have to turn the end cap clock-wise and put your bolts in.the end cap should be under spring pressure so you will have to use some tool to turn it so the bolts can be installed. hope this helps.
morgan
jack
10-14-2002 17:22:47
 Re: Re: JD A Rock shaft reassembly advice needed... in reply to morgan, 10-14-2002 08:09:44
This site is absolutely awesome!
Morgan I hope to return a favor to you someday.
Your help is greatly appreciated! Also what you have said makes the most sense from what I have discovered so far. I'm not a mechanic nor would I say a weekend mechanic, just a programmer/analyst with a hobby collecting stuff. Like I said I watched these guys on a video, show a tear down and reassemble of the power trol. I also talked to a retired JD mechanic who worked on these two-lungers for years. He told me there is no tension on the rockshaft from the spring. So I said to him why did JD put the spring on the rockshaft if it served no purpose? He said he'd have to check his service manuals and get back to me on that. I don't have a manual on the power trol yet, but one's on its way. I was hoping to get an answer that made sense to me like yours. Gee I'm so excited I can't wait to check the end of the rockshaft for that "arrow". I don't mean to discredit any individual or group offering help on these old girls. But being a programmer you get used to searching for a logical solution to a problem.
morgan
10-14-2002 18:58:57
 Re: Re: Re: JD A Rock shaft reassembly advice needed... in reply to jack, 10-14-2002 17:22:47
Jack I am glad I was of some help to you. I had to take my 49 A powr-trol apart a couple of months ago- it was full of gunk. The tractor had been used once in 15 years and that was about 5 years ago.I bought it from a friend who inherited it and didn't want it. There was about 3 inches of sluge in the crank case, I had to take off the cover and clean it out-real hand fulls! The old girl runs pretty good now.Had to do a lot of catch-up maintance.
morgan
Jack
10-12-2002 21:41:33
I thought someone would have known the answer to this. But maybe more time is needed...
