Charging system question
ET
10-10-2002 18:23:35
I have a tractor with an older 6 volt charging system on it that has a cutout relay on the generator. The charging rate is regulated with the light switch by grounding the field directly for high charge or grounding through a resistor for low charge rate. My question is about how many ohm resistor is used for the low charge rate?
