What did i Do Wrong? JD 730 Clutch
Aaron
10-09-2002 16:58:54
I replaced the oil R/H main bearing oil seal in my 730 and after putting everything back together i can't get the clutch to engage or disengage. If I pull back on the lever it will stop the pully and when i push it forward it will engage but no snap. Did i reassemble something wrong?
Thanks Aaron
Clooney
10-10-2002 03:48:52
 Re: What did i Do Wrong? JD 730 Clutch in reply to Aaron, 10-09-2002 16:58:54
Aaron, if you tried adjusting the "adjusting nuts" both tighter & looser with no effect you probably should start over.
~I'm guessing you have the fork in the operating sleeve slot correctly because the pulley brake is working but the fork could still be on the outside of the operating sleeve slot & still apply the brake but not the clutch. So start there [make sure the fork is in the operating sleeve slot].
~Then install one thin lined plate, & then the clutch driver [keep the pulley pulled towards the driver once the driver is installed so the disk doesn't fall down & out of it's recess]
~Then install a double lined disk with the holes over the drive pins [not the adjusting bolts], then install a steel floater disk, then another double lined disk [with the holes over the drive pins not the adjusting bolts], then the second steel floating disk, then another thin lined disk, then the thick adjusting disk [make sure the 3 springs are on the back of it & go into the recesses in the pulley.
~Once it is all together tighten the nuts even with the ends of the adjusting bolts, then engage the clutch, then use the shortest wrench you have or mark a line at 6� on a wrench or ratchet, then hold the wrench the same way at that line & tighten the 3 nuts fairly tight using the same force on all 3 [resist the urge to keep the same amount of threads showing on all 3 bolts as they can wear at different rates & so won�t always be the same]. Then try the clutch action. Adjust the nuts from there in equal amounts in or out until the clutch works & snaps in & out good.
~Once the clutch is working good, remove the top & bottom access covers on the 1st reduction cover & disengage the clutch, then use a screwdriver or pry bar & pry the pulley lightly away from the 1st reduction cover until it is tight on the inner thin lined disk, then use a .060� feeler gage or [I use a piece of .060� mechanics wire] & reach down in the 1st reduction cover & place the wire or gage between the bolt head on the clutch fork & R/H main bearing cover [top & bottom bolts], if they are close you are done, if not loosen the nuts & turn the bolts until you have .060� clearance.
~If it still doesn�t operate properly you probably have excess wear on the sleeve drive pin, pin hole or excess wear on the clutch dogs or toggles. Sometimes just disassembling the clutch will allow the parts that are close to malfunctioning to line up incorrectly & not work properly. In that case try driving the tractor & if that doesn�t allow the clutch to work properly you will have to go back in & find the worn parts��..
G-MAN
10-09-2002 17:09:56
Aaron, providing everything is back in it's proper place, the first thing I would check would be to see that the adjusting nuts aren't too tight. If they are, the clutch will not snap in. Try backing them off a little at a time and see if it will go in. I had that problem on my "G" when I first got it. I thought I had major issues, but backing off the nuts some allowed it to work fine.
Aaron
10-09-2002 18:59:22
 Re: Re: What did i Do Wrong? JD 730 Clutch in reply to G-MAN, 10-09-2002 17:09:56
G-MAN, I Have tried to adjust the 3 nuts but they have no effect on it at all. I think somthing is wrong on the inside. Do you know what would cause this?
Thansk Aaron
RLA
10-10-2002 05:00:42
 Re: Re: Re: What did i Do Wrong? JD 730 Clutch in reply to Aaron, 10-09-2002 18:59:22
How many left over parts did you have???? Sounds like something is left out. Will the pulley turn with the engine?
RLA
Rman
10-09-2002 19:19:35
If the clutch handle would not snap in pushing the handle forward, you have to tighten the nuts, not loosen them. Take them a 1/4 turn at a time tightening them and see how the handle movement is. Get it to make a good snap when pushed forward. If that doesnt work, then you have several things to look at. The 30 series clutches do not work like the letter series do. You have to set the fork inside and adjust the gap between the fork and bolt stops. Try tightening the nuts first and see where that gets you. Post back for further details, good luck
