JD 1010RUS won't start
Bill G
10-09-2002 09:30:36
I just purchased a '64 JD1010RUS. After trailering it home, I went to back it off the trailer and it died. Come to find it ran out of gas. I filled it up and I get nothing. The engine cranks over, but it never catches. So far I have replaced the coil and battery, cleaned the plugs, carb and sediment bowl. I blew the gas supply line clean. It just doesn't want to start. I have tried to pop the clutch and it starts but dies as soon as I push in the clutch or it comes to a stop. It seems like it should be the easiest fix in the world, but I just can't figure this one out. Any help is appreciated. Thanks, Bill
BIll G
10-10-2002 05:11:34
 Re: JD 1010RUS won't start in reply to Bill G, 10-09-2002 09:30:36
Worked on the tractor more last night. Turns out the needle in the carb was dirty and allowing a bunch of fuel into the engine. Got that fixed. Next, checked the coil and it has good spark, but at the plugs the spark is very weak and intermittent. Should I replace the condenser and points or just do the whole distributor? The cap and plug wire appear to be new.
Loren
10-10-2002 11:08:41
 Re: Re: JD 1010RUS won't start in reply to BIll G, 10-10-2002 05:11:34
Take the gas line off the back of the carb, then remove the brass L that goes into the carb. The inside of it is a very fine screen filter. Mine was full of fuzz. You can't really get inside to dig out the junk but I used an air hose and did a lot of blowing every direction on the screen until I worked out all the crud little by litte. When it is clean you can hold it up to a light and see through it.
Bill G
10-11-2002 04:40:36
 Re: Re: Re: JD 1010RUS won't start in reply to Loren, 10-10-2002 11:08:41
I will try that tonight. I replaced the plugs and capacitor in the distributor last night and the spark has gotten noticably better. But it still doesn't start
Bill G
10-12-2002 03:14:44
 Re: Re: Re: Re: JD 1010RUS won't start in reply to Bill G, 10-11-2002 04:40:36
Took carb apart again last night. Cleaned and polished every part. Took L fitting off as well. Put it all back together and after about a 10 sec crank, the tractor started to catch. It took several more starts, but it finally started. Thanks Loren, not sure that the L fitting was clogged, but I appreciate the help anyway. Bill
Jimbob
10-14-2002 17:22:45
 Re: Re: Re: Re: Re: JD 1010RUS won't start in reply to Bill G, 10-12-2002 03:14:44
If all else fails, Take a close look at the insulator in the side of the distributor that has a wire going to the points. Mine cracked right at the point of entry and allowed it to short out intermitte
Bill G
10-16-2002 09:15:02
 Re: Re: Re: Re: Re: Re: JD 1010RUS won't start in reply to Jimbob, 10-14-2002 17:22:45
Well I got the tractor running this past Saturday. Ran all day and I was quite happy. Ran out of dayl;ight and expected to finish up Sunday morning, but as luck would have it, it wouldn't fire up. So I have decided to rebuild the carb. Got a rebuild kit, soaked it, sandblasted, blew air through the passages and I am now in the final stages of repainting. I noticed on Sunday that I had fuel dripping from the throttle arm lever. So it looks like the carb is just adjusted wrong. After all is said and done, I should have a nice "new" looking carb. Hopefully the tractor will start. I'll probably install Friday or Saturday.
