Changing the trany fluid
Steve in WI
10-09-2002 05:50:00
Hello,
Put fresh straight 140 in my trans on my 38 B this spring. the stuff that came out was pretty black. I am planning on changing it again before I put her up for the winter. Any down side to flushing the trans with kerosene, or diesel. Or should I just drain it good and put new stuff in.
Thanks Steve
Bguy
10-09-2002 07:43:39
 Re: Changing the trany fluid in reply to Steve in WI, 10-09-2002 05:50:00
As the other post says, many service manuals recommend this procedure. I have a 35 B and I flushed out the trans and crankcase good with diesel and a scrub brush when I had it down. It took several cycles to get 60+ years of funk out but they were both clean as a whistle when I finished.
flush
10-09-2002 06:16:25
Read the owner's book and you will find that it recomends to flush the transmission . put in fuel then jack up one wheel then run in gear, to flush it good.
