JD A crankcase adjusment force
MENNO
10-08-2002 03:22:51
I want to adjust my crankcase off m JD A 1947. I have adjusteble bearings. I have bought platic gauges, so eveything is ready. My question is: with what moment (force) do I screw down the bearings off the crankcase and the connection rod ???
Thank Mennno Hiemstra from Holland
Seamo
10-08-2002 21:14:17
 Re: JD A crankcase adjusment force in reply to MENNO, 10-08-2002 03:22:51
I dont use plastigage when I adjust shimmed babbitt bearings . I snug the bearing until it drags and will turn over a complete rev. I then add shims to get my .004 clearance. Measure your shims and keep them straight.Equal amount on both sides.They will be in .002 increments. They are laminated.Dont get too tight that is a high volume,low pressure oil pump.Earl in Illinois
CJDave
10-08-2002 03:44:44
Menno, You will be tightening the connecting rod bearings to the same torque (moment) that you would use if the plastigage was not in the bearing. I don't have the numbers, but someone will doubtlessly post and tell you what the torque value is in foot-lbs and then you can convert to Newton Meters or what ever you need to. Dave
dutch
10-08-2002 21:12:06
 Re: Re: JD A crankcase adjusment force in reply to CJDave, 10-08-2002 03:44:44
go to this site for the specs Link
