Hand crank B john deere miss firing or ?
Mike
10-07-2002 18:43:04
Iam new to j/d i have a b that when running at low rpm it sounds like it is tring to fire both cylander's at the same time or a miss fire could the head gasket be blown between the cylenders and gas is passing over and firing or is it in the carb or mag Thanks mike
CJDave
10-07-2002 20:30:58
 Re: Hand crank B john deere miss firing or ? in reply to Mike, 10-07-2002 18:43:04
Uh....Mike. Could you be mistaking a misfire for the uneven firing order of your John Deere? They do fire pop-pop and then nothing happens for about 540 degrees of rotation. At idle the uneven firing order is more noticeable.
Mike
10-08-2002 04:45:48
 Re: Re: Hand crank B john deere miss firing or ? in reply to CJDave, 10-07-2002 20:30:58
Know it back fires nice little flame and all has new cap points wires it is in timethe mag is anyway but at idal it will pop runs fine when on one cylander but when you add the other it will run rough or backfire does not mater witch cylander you take awy or add it does the same thing. I have a h that started this and rebuilt the carb and it quiet but the b wount Mike
AC
10-08-2002 19:39:14
 Re: Re: Re: Hand crank B john deere miss firing or ? in reply to Mike, 10-08-2002 04:45:48
Well, I have had a number of different experiences when it came to messing with these poppers...Never like anything exactly like what you are going through, but here is a few things that might make a difference....Was the motor set up before you got it? Did it ever have water in the bore? What color is the smoke that comes out of the exhaust(if any at all) It could be that the valves are sticky, or the tappets need to be adjusted..neither would correct that symptom, BUT it could help a little. The carb could be rich...did you clean the carb? If you did, did you mix up the load and idle needles? They are different, though they look the same...None of these tractors ran perfectly or evenly until you got into the 50-60-70 on up series because of the fuel distribution through the manifold..I am alittle new to this too, but have spent all this summer messing with about 7 different JD's so I am beginning to learn a little...If the head gasket was bad, you could have water in the oil, a cross-fire which can ruin a block and a head) (did this to my dirt late model ) or it could blow white vapor because of the water, and would have no power. I have found that carb adjustiments are critical. 2 or 4 little clicks over can make a world of difference. See that the plug wires are insulated so they don't jump spark. That Mag puts out a lot of juice...I know I didn't fix it, but these are a few good things to remember in the future ...Hope I have helped a little... AC
