Another ar question
MikeH-Tx
10-07-2002 18:12:26
My axle ends showed some crud buildup, so I assumed the seals needed replacing. Since I had the tractor nearly completely dissassembled anyway, I removed the transmission cover and pulled an axle to take a look.
How the heck do I get the outer bearings removed from the axle shaft? It looks like I need a puller capable of a two foot pull. If I just pry against the oil seal cover, I think I will just bugger it up.
I also noticed that I have two different kind of axles. The left has the oil seal flange very close to the lug nuts, maybe one inch apart. The right has a spacer between the oil seal and the lug nuts of about three inches. Surely this isn't standard...
What do I have, one each of two different axle types?
