Connecting cab heater on 4020
Steven M
10-07-2002 17:58:09
I put a Hiniker cab on my 1966 4020 Gas. I connected the heater hose going to the heater by the rear water bypass pipe, and the hose going away from the heater to the
engine block drain. Is this the right way?
I'm not getting heat. I think it maybe air in the system, but i'm not sure. If it is air, how can i get it out?
Craig
10-07-2002 19:31:54
 Re: Connecting cab heater on 4020 in reply to Steven M, 10-07-2002 17:58:09
I worked on a 4020 with cab heater some years ago, I flushed the cooling system. After that there was air in the heater core and hoses. It was difficult to get bled out. Once all the air is out the coolant will circulate just fine. I remember disconnecting the hose from the heater at the top of the cab with the engine running, I reved the engine up and let it run, after 5 minutes or so the coolant expanded enough to push coolant up the hoses till I had coolant coming out the hoses at the top of the cab. I reconnected the hoses then and all worked well after that.
