AR oil lines again
MikeH-Tx
10-07-2002 17:47:23
Thanks Cal, for the advice.
I thought I would take a picture and ask again.
I don't think the oil lines were connected right on the AR that I bought. See what you think.
The connections to the main bearings were right, and to the oil pressure gauge. but the connection to the governor and one other connection make me nervous. Take a look and tell me what you think.
Thanks,
Mike
MikeH-Tx
10-07-2002 18:29:01
 Re: AR oil lines again in reply to MikeH-Tx, 10-07-2002 17:47:23
Sorry to prejudice opinions, but I bet one of the questionable lines from the pump is the oil supply to the governor. Since mine was not connected right, maybe that is why the governor gear is so rusted. What is the other, a discharge line?
Gpower
10-07-2002 19:32:43
 Re: Re: AR oil lines again in reply to MikeH-Tx, 10-07-2002 18:29:01
The ones in question look like one is for the governor, the other for the valve train
Cal
10-07-2002 22:52:52
 Re: Re: Re: AR oil lines again in reply to Gpower, 10-07-2002 19:32:43
What year is your AR? I agree one should be for the valve train.
MikeH-Tx
10-08-2002 06:56:11
 Re: Re: Re: Re: AR oil lines again in reply to Cal, 10-07-2002 22:52:52
Cal, mine is a '51.
Thanks guys. I see the fitting for the valve oil supply and will make an oil line for it. Do you think it matters which outlet on the oil pump goes to valves and which goes to governor?
