JD 2150 hydraulics
what's wrong here?
JT
10-07-2002 15:49:34
First - I know nothing about hyrdaulics, and less about tractor maintenance.
Have a JD 2150 that suddenly lost all hydraulics - power steering and 3-pt. Checked fluid - it was low - put in 4 gallons - still no hydraulics. Checked the resevoir above the hydraulic pump - it was empty. I fill it up too, and I had hydraulics for a few minutes - I assume until the resevoir drained. So this tells me the pump is ok. What is keeping the resevoir from filling back up? What areas should I look at?
Jim B
10-07-2002 18:24:15
 Re: JD 2150 hydraulics - what's wrong here? in reply to JT, 10-07-2002 15:49:34
JT,the hyd. filter is under the footrest on RH side,the screen is under the diff. laying crossways and trans. pump is under rockshaft housing.You should invest in a tech. manual as it would be very helpful diagnosing problems.Jim B
Jim B
10-07-2002 16:05:46
JT,have you changed the filter and cleaned the screen in bottom of transmission case?If you have then possible trans. pump failure.Jim B
JT
10-07-2002 17:39:12
 Re: Re: JD 2150 hydraulics - what's wrong here? in reply to Jim B, 10-07-2002 16:05:46
Jim - Thanks for the reply. Pardon my ignorance - but then there are 2 pumps in the system - a main one up front and one in the transmission?
How accessible are the transmission pump, filter and screen?
