Fixing leak around PTO shaft ?
Mike
10-07-2002 11:59:07
I have a 1946 Model "A" that I recently began utilizing the PTO on and now, it leaks. Is it possible to replace the seal on the PTO shaft without removing the rear cover ? The tractor does not have a power-lift. A quick look at the parts manual shows a gasket between the PTO shield housing and the rear end housing and a seal just behind this gasket. I'm not sure what this seal is made out of and I'm not sure if I can dig it out and then install a new one, all without removing the rear end cover.
Thanks for any tips,
Mike
Clooney
10-07-2002 16:28:42
 Re: Fixing leak around PTO shaft ? in reply to Mike, 10-07-2002 11:59:07
Mike, you will have to remove the PTO housing [the little cover held on with 3 bolts] to replace the power shaft seal. At that time you can install a new seal in the housing & bolt it back on with a new gasket. Be careful if you pull the PTO shaft out that the inner coupling doesn't fall into the trans, if that happens you will be pulling the whole rear housing.
