JD 60 Carb Problems
Scott
10-07-2002 11:43:10
Can't keep gas from leaking past the needle valve in the carb. Can't see anything wrong with the needle or seat. Float is good and adjusted per the book. Any tricks to make it seat. Dealer wants $30 for a new needle and seat. Have to turn off the fuel every time I stop.
Don Wadge
10-07-2002 12:26:00
 Re: JD 60 Carb Problems in reply to Scott, 10-07-2002 11:43:10
What I am about to tell you is not always the solution but does frequently solve the problem and costs nothing. Take some fine emery cloth (or emery paper) and roll it small enough to go into the seat cylinder (not the actual seat area but the cylinder area that the needle runs in). Polish this area up so that it is clean and smooth. Then polish the three points of the triangular sides of the needle. This will allow the needle to run in the seat cylinder easily without binding. You should also make sure the point of the needle is clean and smooth as well as the actual seat. You need to be careful doing much to the seat and needle point as you could cause a problem in this area but they do need to be clean and smooth as well.
