1010 3 Pt Lift Problems
Tony Miller
10-06-2002 18:42:31
I just bought a 1010 with a non functioning 3 Pt. At first it would lift slowly, then only if I lift the arms to help it. I've read many horror stories in posts about trouble shooting this thing, but here's something interesting I found. Under the rockshaft housing in the valve housing there is a bypass valve for diverting the oil flow to the resevoir when it is not needed. This valve is retained by a threaded cap held in with a snap ring. It appears that from years and years of oil (probably contaminated) flowing through this valve (any time the engine is running and the 3 Pt is not raising), the port in the casting is actually erroded slightly so that this bypass valve no longer has a good seat to seal against. That means some oil is always being lost even when it's needed elsewhere. There may be a tendency for the valve to catch as well, allowing all the oil to return to the resevoir. It's going to take some machine work to build a new valve seat and insert it into the casting, but I'll let everyone know how it works when I get it back together.
Tony Miller
10-09-2002 21:28:26
 Re: 1010 3 Pt Lift Problems in reply to Tony Miller, 10-06-2002 18:42:31
My 3 Pt is back together and working great. I definitely found the problem. Anyone with a none functioning 3 Pt on an M,40,420,430,1010, I suggest you look at the bypass valve I described. I would even offer to help anyone fix their 3 Pt, or at least offer the part I made for less than $5.
