History by serial # and looking for an MC
hick
12-24-2003 14:52:30
A couple years ago I posted a serial # for my '37 B and someone was able to give me the shipping date and town the tractor was sold from.
He also gave me a link, but I have lost it.
I am trying to track down my Dad's MC crawler. He had bought it new and sold it about 30 years ago.He does not remember the serial #. I think I may have found it. I have the # of the crawler I found and was wondering where it was originally sold.
The # is 18618, which was made in the 1952 model year. One source I have says the serial #s run from 8-1 to 7-31. If this is true, 18618 would coincide with a purchase in the fall of 1951, which is when Dad bought his.
There are a couple of strong indicators that it COULD be Dad's, except for the dozer that was with it. It appears to be a homemade chop job; Dad's was the inside-of-the-track dozer from John Deere. He had welded 10" extensions on each end of the dozer.
Any help in finding info on 18618 would be appreciated.
Also, if any of you out there know of an MC purchased in the Loup City, NE area contact me, it may be Dad's.
I would REALLY like to find Dad's (and may have). But if the one I found isn't Dad's, I may buy it anyway.
What is an MC with good tracks and sprockets but not running and possible stuck engine worth? There has been a lot of welding to the frame (adding who knows what, then cutting it off!), the sheet metal is there, one fender missing, the other with a corner cut out. It has been sitting outside for about the last ten years.
Gary Hickman
MIKE HANLEY
12-25-2003 09:13:13
 Re: History by serial # and looking for an MC in reply to hick, 12-24-2003 14:52:30
Can't help with the serial #, but and sit down for this, if it's the way you discribe, the sprokes and tracks are shot too, along with the steering cluchs and brakes shot or at least set up. Could easly top $10,000 to $20,000 to got through it complety and to do it right. I'm talking to do it right, and not just "well we'll get buy with this part." I've been down that road before and have been sorry everytime when I had to do it over the next year. Gave that up years ago, and now replace EVERY questional part. We just finished a 430 crawler and we have topped $20,000 on that. Radiator cap to drawbar. The engine was I think $2,300. When it came to the tracks, we pulled the whole assembly off the crawler and put them on saw horses. Alot of welding build up and grinding to get it back to proper wear points. 5 new complete rollers and the rest machined bushed and new pins. When we got into the steering cluchs and brakes, it wasn't just disc's and bands. We had to replace all the linkage as well eather for wear or set up and just about rusted through. We had to build up the drive shaves and then machine them back down to fit the new bearings. We haven't done anything to the tracks proper yet, and should replace the drive sprokets, as we still throw a track from time to time. Not that I want to discourage you, just tell it like it is.
hick
12-25-2003 18:49:09
 Re: Re: History by serial # and looking for an MC in reply to MIKE HANLEY, 12-25-2003 09:13:13
Actually, the tracks and sprockets look very new (other than the ten years of rust!).
Thanks for the heads-up on costs!
Gary
MIKE HANLEY
12-26-2003 02:51:59
 Re: Re: Re: History by serial # and looking for an in reply to hick, 12-25-2003 18:49:09
What jumped out me was that it has sat for 10 years and the engine is set. The only way to check the brakes, cluch and the undercatrrage is to drive it, (which can't be done) or to take it apart and inspect it. You can't tell any of that stuff by looking at it. You can't tell the condition of the front iders or the rollers pins and bushings with tention on the tracks. You have to drop the tracks. There isn't any type of lub in the cluchs or the brakes and without use to keep the parts shiny you can't see what 10 years of condensation has done to those parts. I would say you stand a good chanch of haveing the disc's rusted to the metal dics. And if they are pitted, they need to be replaced or the new cluchs will not last. What I'm saying is that there is way to much that you can't tell what it's true shape is until it come apart.
hick
12-26-2003 12:49:56
 Re: Re: Re: Re: History by serial # and looking fo in reply to MIKE HANLEY, 12-26-2003 02:51:59
Good points, Mike.
It is always good to get the voice of experience BEFORE getting into a project!
Thanks!
Gary
